Highbulp Billy
I\'ve recently discovered my local ModelZone and their stock of Tamiya Paints. After a quick search of the forums I found that some of you rave about the \"clear red\", \"smoke\" and other bits so I had to try them. I also got some pots of other things that I\'ve not used before, namely:
- Flat base
- Acrylic thinner
- Clear
I used the thinner with my current GW range of paints (was a bit nervous as I understand that they\'re a different formula from Tamiya) but it seemed to work really well.
My main question was regarding the \"flat base\" - I\'m guessing that you add it to a paint to make the result less shiny ??? Have any of you used it with GW paints (also the \"clear\" with GW paints) and did it work?
I\'m new to using additives other than water (which I can\'t get the hang of
) so would welcome the voices of experience...
- Flat base
- Acrylic thinner
- Clear
