Hello all, excited to finally getting around to joining CMON and making my first post
I am a relatively new painter, been about 6 months now, and trying my hand at some more advanced techniques to push myself to keep learning.
I am currently working on a Stormcast Eternal Liberator. It's my first attempt at NMM and I've been following along with the very inspiring Painting Buddha tutorial https://www.youtube.com/watch?v=VepXVggrfiE
The colours I am using, which I mix into a gradient on the wet palette, are the following (from shade to highlight): German camo brown, Armor brown, Balor brown (as the midtone), Yellow Ochre, and Off white.
So far I have reasonable success with short blends when it comes to smaller areas that I can cover most of the surfice with the side of the brush. I am able to gradually build up the layers with perpendicular strokes. However, when it comes to large, curved surfaces, like the thigh armor (see pic A, **these are screen shots from the tutorial video just to illustrate), I am not able to cover the entire length with one stroke and thus getting more abrupt transitions between stroke as I try to line them up.
To overcome this, at first I was trying to slowly blend with small parallel brush strokes instead (see pic B). This worked well in the past for soft objects like cloth, while also adding some nice texture, although having that sort of interlaced line pattern for NMM just doesn't fit.
More recently, what I have been trying are cross-hatches (see pic C). I find it better than just the straight lines, but it's still not ideal for getting short enough of blends for a smooth transition. Plus it's very time consuming.
I am wondering now if I could try making glazes again with perpendicular brush strokes (see pic D). It's overall much faster but then prone to those dreadful "coffee stains". I realize those can be feathered out with a damp clean brush; however, I am slow at switching when it comes to 2-brush blending and the paint has usually already dried, causing said stains. I was thinking my other alternative would be licking my brush to clean it and then feathering, but I am trying hard not to succumb to that
When I watch Ben do this (on a smaller surface though), for instance between 14:00-15:00 in this video https://www.youtube.com/watch?v=ChGgM0aF3UU&t=13m56s, he is able to create blends so incredibly fast. At some points, it looks like he's just push-pulling vigorously and then right after there's a nice transition that magically appears! I guess that's the kind of brush control a master gets after so many years of practice >.<. From what I notice, he often glazes perpendicular and I'm trying to achieve similar results if possible.
I've probably spent around 15-20 hours playing around and restarting with different techniques but I can't seem to figure it out. It's starting to get more frustrating than fun. Ugh. Again, the smaller areas like around the feet, knee, and waist I find are quite straightforward. It's the fatter areas that are problematic because uneven streaks start becoming more apparent.
I realize NMM requires lots of patience and I am more than willing to put in the time and effort it takes to get better at it. Would love some advice and tips on how to keep progressing.
Much appreciated.
Much appreciated.
