Hi guys
So today I had my first RPG session with minis introduced to the mix.
Sadly the players minis were only at the undercoated stage.
I discovered after the game that one mini had lost the undercoat from pretty much every corner and raised surface that the fidgety player could get hold of.
I had been super-anal with mini prep and washed the metal minis after cleanup and before the undercoat went down so I'm surprised and disappointed at the damage.
Sadly the weather of late was too rubbish to get some dullcote on there (but of course today is ideal...) but I figured it would have been overkill to do that anyway.
So, the question is, is it unexpected to have primer come off so readily? I didn't see any rough usage of the mini (very little combat so not much actual use of the little guys).
I used Vallejo Model Air Gray Primer 71097 with no dilution, beyond the water on the brush.
If primer is so weak, I may as well just start with Reaper HD paints and speed up the painting process by a stage.
