Trouble deciding where to place/pick colors....
gr33n
http://imgur.com/m6valwj is the model and the red/green/white is the color scheme. I'm not sold on just these colors but I was aiming towards a green and white color scheme. The red is nice but this model has odd extras that make this harder.
could use some advice/suggestions
Antar000
You don't often want pure red and green, or else your model will look like a Christmas decoration. I'd say go with a green and white scheme, with 2 different whites: one cold, going up from grey (shadow -> space wolves -> white) and the other a bone white (Desert yellow to bleached bone with spots of white), so you have a bit of variety on the mini. As for the green, that's up to you, though a darker forest green color might emphasize the elf-ness of the Eldar. Finally, for the red, I'd start the wraithbone from a reddish color, maybe add some reddish glazes to the metallics (this is a good article on that subject: http://www.coolminiornot.com/articles/1649-metallics), so you have a subtler contrast. As for the soulstone bling that the Eldar love rocking, the turquoise blue you chose was a good choice. It's greenish enough not to seem out of place, but not so green that it blends in and doesn't pop.
Good luck!
Antar000
I'd recommend making it white or green, just like all the other fabric, but with a single twist: some turquoise blue runes or markings on it. That way, it still pops because it complements the rest, but you're not making the sash stick out like a sore thumb.
That said, Red isn't a bad idea, especially if you start from a purplish base and build to red, to keep a cooler color scheme. If you do the same colors on the eyes, you'll have some nice balance.
Finally, a piece of advice is to ignore the codex. It's hard and I have trouble doing it too, but everything in there is a suggestion. My Biel-Tan are blue-grey and jade rather than white and green, I paint Space Wolves a more neutral grey, my Salamanders end up a good deal darker than Snot Green, etc.
But if you feel like something needs a change, try out something new. I don't know if you're using a metal figure or not, but if you are, experiment. The worst that happens is you strip it of paint, you lose some hours of painting, but you gain experience. Try something bold and push yourself. Or, just paint it like the rest of the fabric. Exterior of the cloak color, or something. Not every detail needs to be emphasized; some things are just decorative.
gr33n
the model is trouble all over. the sash im unsure of a 3rd color that wont clash but also that collar. the collar and lining of the cloak. the reason this is an issue is none of the back cloak spills over. I don't think a white robe with a white sash would look very good no offense...
Zab
The red will be fine if you use some of the green to shade the recesses it will tie into the green without being jarring.
