Ugly Whites!!!
Gussy
What am I doing wrong here??!! The shoulder pad skull symbol and helmet. I don\'t think there is a brush small enough to do black lining. A wash only makes my white darker.
Is there a way to fix this, or I should just call it quits on these whites?
Thanks!
matt15595
go over the white again with slightly thinned down white.
Then use a really light blue wash to shade it
its just the edges so go over them with normal white
Gussy
When I wash...blue or black, everything goes dark. I tried diluting the ink a lot to a point where it wasn\'t leaving anything anymore. When you wash, should the white take on the color of the wash?
well it normally stains it. hence the need for re highlighting. you can also thin it down and put it on with a brush in a controlled fashion so it doesnt pool. that will take a while and i get the feeling you don\'t want to spend ages doing it!
Gussy
I don\'t mind doing a few coats but would that be enough? It\'s been two months and I\'ve barely making a dent on my figures. Next time I should just use another color.
No need to use a wash, you neet to know how to LAYER but more importantly you need to start using intermediate colours for those tricky ones. i.e. Yellow, Red and White.
When using these colours you need to use a basecolour that is closer to the desired colour but has good coverage properties.
Light greys for White.
Orange for Reds.
A mix of Yellow and White for Yellow.
LAYERING.
When layering over detail you need to angle your brush 90 degrees so that the brush only touches the raised areas.
So if we start with a black undercoat on the shoulder pad with Terminator Honors, Layer on Shadow Grey remembering to hold your brush 90 degrees to the surface to be painted. This will leave the eye sockets, nostrils, teeth and the surrounding recesses black. The final stage is then just layering on a few coats of Skull White over the Shadow Grey. Belive it or not with this technique I can get pure white with only 3 layers of white.
Please note: Your paint needs to be 1/1 (1 part paint, 1 part water) or test the mix untill your paint doesnt run into recesses.
Also you might like to look at my Terminator Painting Guide here http://www.spacemarines.co.uk/stage1.shtml It uses an Ultramarines colour scheme.
Gussy
Thanks guys! I\'ll just try to clean up my whites for now. I guess is another set of terminators later. I could always use another 5 figures.
Jericho
Consummate Brushlicker
You can also do washes with heavily watered down paints, you don\'t have to use ink. Watering the heck out of Codex Grey or Shadow Grey can work for shading white, you can generally control these washes a bit easier than inks I find.
Don\'t worry about getting your whites perfect if you\'re new to painting, it\'s one of the tougher colors to get used to. One thing that can work is to spray prime pieces white if they have a lot of white on them, then you can just paint the rest of the piece dark colors and paint as usual. A bit more prep time but it causes less headaches.
