Hi there,
lately I have some problems with my paints, of which I can really make sense of:
I use the technique of layering my paints, so I use layer over layer over layer of really thin paint to get my results.
Now after about 5 or 6 layers, the surface starts to get uneven - like I use some way to thick paint - getting stroke lines of paint and generally a very "textured" look on my mini.
So, easy guess is, I use to thick paints for layering, but they are so watered down that you barely see a difference after applying 2 or 3 layers, so I am not sure whats causing those lines.
It really just looks as if I took some paint out of the pot and applied it wihtout feathering it out. I am really confused here, as the transition from dark to light and so on is really smooth.
Some words for to the technique:
I don't flood the mini with paint or anything, I dip my brush into the paint on my wet pallete (so paint drying up and getting thicker isn't the issue either!!) get rid of the "too much paint on brush" on my painting cloth and then apply the thin paint on the mini. I just cant figure out whats happening there - its mostly on flat, big surfaces like a terminators top or armor plates of tanks etc - I am confused here, maybe someone can help out ^^
