nosirrahkcaz
I just got an airbrush for Christmas. Can you use it inside without a ventilation hood if your only using acrylic paint? or do I need to take it to the garage? Thanks
The simple answer is yes, but it's not that simple unfortunately.nosirrahkcaz said:I just got an airbrush for Christmas. Can you use it inside without a ventilation hood if your only using acrylic paint?
Cleaning is touched on in many of the prior threads on airbrushing. I think basic instructions on making your own spray booth can be found in a thread here too.nosirrahkcaz said:Which leads me to the next question. When using paint like GW, Vallejo and Reaper for clean up is just water okay or should I purchase a "cleaner"?
Good way to start BTW.nosirrahkcaz said:I messed around with the brush a little bit tonight. I just shot some water through it and practiced.
Oh really?Chrome said:as long as you have a dedicated area inside it really shouldn't be a problem if you're using GW paints and the like.
That's the danger with water-borne paint, the lack of an obvious smell is equated with "Oh there's no danger", like you just did.Chrome said:spraying with them doesn't smell as long as you don't use some aerosol propellant.
Yeah, you could be happy... but would you be safe? Answer is no.Chrome said:So, unless you use an aerosol propellant you could just use it on your workbench and be happy.
This has a grain of truth but for a start the volumes are likely very different - I've never seen anyone spray their hair off and on for an hour or more... more importantly there's no pigment in hairspray, plus any of a number of other ingredients I mentioned just previously in another thread.Chrome said:But then again, using aerosol inside isn't much more different than the missus using hairspray in the bathroom, you never see them ventilate there when they spray do you?
It's not hijacking to post disagreements/corrections to another reply; it makes no difference whether the same ground was covered previously by the two respondents.But I believe you and I have been here before in a previous thread and I think it might be nice to not hijack this thread as well, I believe we could go on for ages otherwise.![]()
Well I finally took out the airbrush and laid down some paint. What a cool experience. A different skill set but super fun, like painting my first mini with a brush all over! I would have purchased one long ago If I knew I was going to have that much fun. On the safety side I took the airbursh set up out in the garage with a mask. I found a space heaters alot cheaper than a spray booth! Thanks for all the help and information from everyone.
Hey! congrats on getting the airbrush. What kind did of airbrush/compressor did you get? I bought myself one too this boxing day (Iwata Revolution BR and a 3 gal tank/compressor). Like you said, it's tons of fun and amazing how much time it takes to apply smooth coats vs doing it with a brush. I'm still getting adjusted to the dual action trigger though and trying not to do too much overspray.
I built a small spray booth after I got the brush which is basically a cheap cardboard box with a hole cut out and a table fan. From the hole I've connnected a 7" vent duct (the kind you use for a clothes dryer) and when I'm about to paint, I just take the other end of the duct and put it outside my window. Works well and as long as you're using acrylic paints, it shouldn't be an issue (maybe metallic paints might be more hazardous). For cleaning I bought a small bottle of iwata cleaner but I heard you can use Windex (window cleaner) to clean it just as well.
