Hi guys! I've allways been an avid converter, but this is the first vehicle I've actually painted since building model airplanes as a kid.
Hopefully I'll get the camo and detailing done today.
Just done the basic green (knarloc green washed with thrakka green).
Painted all the metal, and painted the red tubes.
Still alot of work to do, detailing all gauges, do some greenstuff work on the leg piston, then do my camo (black boxes filled with grey, as can be seen on the barry). Wash it all in devlan mud and finally paint on some battle damage and "dust" up the legs and lower sections.. The "driver" will be obscured behind tinted black windows made from blisters with the inside sprayed black, but that'll be the last thing I glue onto the vehicle, after the varnish. I'm also press moulding and sculpting a skull to go onto the empty area above the cockpit.
Anyhoo, these pics are for me to see anything I've missed, but I thought I'd share 'em with you too. more eyes are better than one pair..
And finally my scorchas converted from KMBs (all weapons are magnetized for easy swaps)
But I have a bit of a question:
I'm going to try this technique for adding some battledamage/wear 'n tear to it; http://thepaintingcorps.blogspot.com/2010/04/its-been-while-since-ive-really-dug-in.html
Now, what colours should I use for that? atm the hull is knarloc green with thrakka wash. I've only seen that technique used on "lighter" colours...
should I devlan wash the model before or after doing that??
Oh, and should I mount the "arms" like I have 'em bluetacked in the above pics, or should I make 'em in the Y position?? (ie, arms slightly upward)..
Thoughts? suggestions and ideas are welcome as allways.
//Calle
