A good job here. I like the tones used, you have a nice colour shceme.
I agree with finn on the harsh blacklining between th fingers : a bron would definitely be better.
The metal on the blade needs more work : the highlites are harsh, and given what you did on the other parts of the mini I\'m sure they could be a lot smoother
Then there is a problem with the blue bit of tissue. Why is it so highlited on a single point, while other parts that should be highlited the same way, if the light was coming from the top, are so dark ?
Obviously you put a lamp before the mini when you took the pic. That not so good, since the flat areas reflect the light and hide your work. It\'s better to have it come from the top or from the side, with a white reflector on the other side then. (Well, that\'s what I say, but I can\'t take a proper photo of my own minis
Then the cape isn\'t highlited enough. On such a large area, the light would flow, and the result would be much brighter than what you actually did. How many highlite stages are there ? I can see something like 4... But it might be the pic.
And the highlites are not coherent : if the light was coming from the top, some of the places hat you highlited would be dark (the part of the shoulder under the cape). By the way, I think the skin lacks depht.
Well, that\'s all that I can think of for the moment... The base is very nice.
Well, an 8.... Had the base been less good it would\'ve been a 7 though
Hope that helps !
