Originally posted by Itchy
well, they curtained off my face so i had to watch via tv. oh, and they used an air powered (actually it was a Nitrogen bottle) die grinder type tool with a tiny drill bit.
immagine the fingers cut almost clean off, held on by (so they showed me) some skin, a blood vessel and some nerves (luckily).
from here on out i\'ll just describe the pinning part
so he hinged down the tip of the finger and drilled two holes clean through the bone and skin, then he hinged up the finger tip and lined up the bones (lost a joint, so my two finger bones are becoming one finger bone) now with the bone lined up he put a guide to keep them in place (went around the whole mangled finger) and then traced through the holes he drilled through the first part into the second part. then cut the wires short to let the skin grow over it. the pins will come out in 8 weeks, but barrying them this way helps prevent infection to the bone
so in mini speak
say you\'re pinning an arm. take the arm bit and put the hole where you want the pin. then line up the already drilled arm bit with the body and secure it down any way possible. then using the hole in the arm bit as a guide, drill into the body. cut your pin a little short. patch up with gs. that\'s how doctors do it to get your bone pinned perfectly straight, so it\'s good enough for me
