How to create gilded metallic armour?
Andaah
Hello! I am about to paint a Slaanesh champion and I would like to create some gilded armour for him. Something like this:
http://www.ashokaarts.com/armour/arscrolldhal3.jpg
I mainly use GW paints but I have no idea how to achieve this effect. Paint on a darker metallic and then paint over with a lighter metallic pattern and wash?
I genuinely have no idea. Heres what i am aiming for:
i would say paint the armour in darker shade than normal. shade and highlight normally (but keep it darkish) and then use a bright highlight for it to stick out. have and experiment and post pics!
EArkham
Necromancer
There are two different ways that I would attempt it:
1) Paint all the gilded armour in your gold colour first, add highlights where such would appear, but exaggerate them strongly. After this is dry, paint black over, leaving thin lines where the the gilded lines would be. Over this black, work up your metallics while leaving a tiny sliver of a black line bordering the gilded line.
Advantages: far easier to highlight the gilding lines, and often it\'s easier to create a pattern by blacking in an outline than it is to paint the pattern freehand.
Disadvantages: you REALLY need to have the pattern planned out exactly as any mistake with the black lining would be much harder to correct, and you obviously won\'t be able to drybrush the metallics.
2) Paint the armour as normal. With a very fine brush, add your gilding pattern in black, then put gold/silver over this, then highlight the gilding.
Advantages: A lot more intuitive method of doing it, and mistakes would be easier to correct.
Disadvantages: Often it\'s harder to free hand a complex pattern as opposed to just blocking in the borders to the pattern, and highlighting the tiny gilding lines properly will be a much larger challenge.
In both cases, you\'re going to have to rely on a brush with a very fine tip and appropriately bright shade of gold or silver for the gilding (such as Vallejo\'s Metallic Medium, which is practically metallic white). Also, I think the key to making this sort of thing work at the 25-28mm scale is using black (or a dark brown, dark grey) to define the gilding -- anything as subtle as what\'s in that first linked photo is simply going to be easily overlooked without some exaggeration.
The Inquisitor there looks a lot more like tactic two to me, and the gilding obviously isn\'t that fine -- it\'s just a few well-placed freehand lines, really.
Hope that bit of rambling helps!
Kep
good idea
what would even be more bombastic if you did homey\'s #2 tech........but before you laid down the silver...put a thin white line in the black free hand....then use sliver....
much brighter....and if the silver went outside the white line its now gold->black->black silver->crazy bright silver....
i like the idea....
cool....
rihadol
uhmm... if you want to do it metallic just water down some boltgun metal/tin bitz and paint some thin lines of beaten copper...
Remember to keep us informed on the results!
Beelzebrush
Bloody Hell!
That\'s one of my paintjobs lol!
Actually Andaah, I just read your PM about this mini.
Right, I\'m just tryting to remember how I did this :)
I think the colours that I used were Vallejo Model Colour metallics...
Gunmetal Grey (179) - (Basecoat)
Oily Steel (178)
Natural Steel (177)
Silver (Game Color)
Old Gold (173) - rivets
I think I just started with the base colour and highlighted using the above colours ending with Silver as the last highlight.
There was also a lot of washes and thin tones used to shade and weather the armour - probable colours used being black, red leather (136), Dark Fleshtone (GC), parasite brown (GC) cobra leather (gc) - these were painted very watered down and built up in transparent layers.
The bulk of the armour was kept darker and highlighted mainly at the edges. The damascus type effect was created by painting scroll work in silver - it stands out against the darker armour and gets lost against any highlighting. - (actually, to be really clever, you could continue the pattern into the highlighted arees using a darker metallic line)
All layers were definitely kept quite thin... better tones achieved then
I hope this helps... I\'m really trying to drag this up from memory. If you have any other questions, just let me know and I\'ll try and remember how I did it lol
Unfortunately I no longer have the mini to refer too :(
funnymouth
hi all, i was so inspired by this thread (a month ago) that i had to try my hand at it. i used method #2 ( thanks for the tips EArkham, i hope no hard feelings).
i started with a base of tin bits, then did the gilding in burnished gold, i then hilighted the base tin bits with brazzen brass, then i finished up by hilighting with shining gold (i may have gotten my gold names mixed up, which one is the light one?) and finally mithryl silver. fun stuff.
link for voting: here
edit: fixed the link
EArkham
Necromancer
Hard feelings over what? That other thread? Think nothing of it! :)
Nice job on the armour. I think it came out quite nice. Voted, though your link doesn\'t work (had to just go by the number).
Not sure about the red sword next to the purple... I like them both, but together they seem just a little strong.
Kep
