Khonner's WIP
Again, I'm liking what I see on both. That said, let me offer some helpful hints.
First, what Stew said. There's too much just gray. Very sharp zones of pure black, a few areas of white and close to white, and then some mid tones. It should probably be mostly black and gray with a few bright light areas. My advice would be to look at a whole lot if black and white art and try to notice some trends with what percentage is what color.
Now the witch elf, but I've also noticed this on a couple of ur other pieces. I'm sure it's mainly because it's just a WIP shot, but your shadows tend to get a little chaotic. Like the shading on her stomach. Frankly, you it would make sense to reduce about 95% of that shading. That same level of darkness should exist only around the contours of her clothing. Maybe a lighter shade near her belly button, but that is it. Women's skin takes VERY subtle shading. Next, you have the right idea with the shading on her inner thighs, but again the surface area of the shading is too much. Could be reduced by probably 50%. Again, I know it's a WIP so you probably were just blocking in colors, but just in case ;)
on areas like skin , it's very important that our shades and highlights have clean edges. What I mean by this is the shadow zone should follow the contour of a muscle or dip in the flesh, etc. ....hmm this is tough to explain. Like on the legs. The edge of the shadow should not be a squiggly line, it should be a straight line that follows the shape of her thigh. Let's say I am shading a fist. The shadow in between my fingers should be relatively straight. The edge of the shadow should not spill out all over the finger chaotically.
I hope this makes sense. You have the right idea with the shape of the shadow on her shoulders, but again the area of shadow is too large, and the transition is too abrupt. PM me or respond here is any questions :$
Khonner
I have finished up the witch elf for WAMPs AoW competition. It should be up for voting soon. Comments always welcomed!
Wow, honestly very impressed with how she came out. Love the NMM brother!!! Your getting it down quite well. It looks a lot cleaner too so good improve ment there. And of course the base is great!!!
Khonner
Here's another that I worked on last week. Just need to base em and he should be done. I used the new airbrush on the skin and I'm pretty happy with how it came out. I used the salt method for the rusting effects. I want to try it again on a bigger area next time.. Comments welcomed as usual!
Khonner
Here's another WIP on the table. I used to play the Stormbringer RPG in college and almost lost my mind to find an actual mini of Elric.. Trying for another form of albino skin tone, since in the books, Elric is an albino. The wife thinks that the skin tone is too grey, I'm on the fence with giving him another bath in simple green and give it another try.. Opinions?
KruleBear
I would say it needs to be whiter, but am greatly influenced by Brom's paintings of Elric. May want to add some purple veins in there as they would be more apparent on a lighter albino skin.
And i am jealous you actually got to play Stormbringer. All i did was read several times, build adventures and characters, and hope to find some nerds willing to play.
Edit: example from Hellboy:http://theminiaturespage.com/boards/msg.mv?id=257370
Bailey03
I think it looks fine. You could lighten it up some, but I wouldn't strip it and start over. You've got some nice directional highlights across the face and top of the leg. You could maybe brighten up the left bicep. We're looking at the underside of the right arm, so it should be in shadow. But the other side should definitely be lighter.
You could take thinned down blue or purple glazes (I use GW's Guilliman Blue and Guilliman Blue mixed with Bloodletter Red, then dilute them to about 2 parts water to 1 part glaze) and tint some of the shadows. I might hit the shadows in the cheeks, perhaps in the brows, and then maybe a few spots on the arms and legs. This would give you a more stylized look. If you wanted more realistic, take a look at albino reference images on google. In that case maybe a subtle glaze of regular skin tone over the shadows might work.
Agree with Bailey. I actually like it a lot. I get the sense of some very pale skin from it. Albino skin often just looks weird and I think you'd be disappointed if you tried to paint it. But yes some thin thin purple glazes in spots would really set it off. My Dark Elf project, which a ton of people told me reminded them of Elric-who I've never heard of-had a grayish white skin tone with purple shadows.
Your layers are getting much smoother brother. Good job there I have to congratulate you on that. Just be sure that additional layers for highlights and shades are just as smooth and you are really stepping it up.
Drizzt Do'Urden, now that's a real dark elf.
Khonner
Here's another attempt with black n white.. This is on a smaller scale with a Slag Troll.. I need to apply the final highlights and I was thinking about like an acid green for the blood coming out of the wounds... Thoughts?
