@Milosh- I would really LOVE to see your take on some of those
@KB- yeah the red is really dark, i was planning on brightening it up but i wanted to see how it was going to look with the gloss coat. That blue thing will be a 40k bunker or something.
@Marj- Thanks, and i would LOVE to see one painted up by you as well
@Meph- Get cracking sir! I do believe you were one of the first persons to inspire me to get an airbrush in the first place. Cheers to you!
@Tryst- I shall watch it eventually, but i want to paint while i got the painting bug voodoo.
@Ceal- I'm always happy to hear something i did helped someone else.
Which is why I'm going in a totally different direction again. We played a game of heroscape(i think, i didn't like it too much personally) the other day on part of the table that had the river cut into it. Never fails, eventually someone gets excited and a die rolls to the floor. I decided then i was going to get a couple of dice towers. I then proceeded to look up dice towers online.
Some of the ones i'd seen were like 100$ each. No friggin plastic die is that damn important. Time to make my own.
I used one sheet of elmers foam board 20X 30X 3/16th inch. This made both of my towers with this one sheet. And just an FYI my measurements were off on them both so i had to adjust as i went(i didn't compensate for the thickness). It wasnt that big of a deal so if yours is off a bit don't panic.
I also Used a hot glue gun, and two sheets of sheet styrene.
Total cost less then 5$
I just started measuring out about how tall i wanted it to be and about how deep i wanted the try to be. I've seen some made out of cardboard 15 years ago at the place we used to play 40k, so i was just going with the square wizards tower shape. I may paint them up later to use as actual stratigically placed terrain for the game players. Who knows?
As i went i wrote down the length i measured and what that piece was actually going to be:
I then took a SHARPE box cutter and started cutting out the pieces. A dull blade will cut you more often then a sharp one.
I then split the pieces up into the two sets and started with a corner:
I then had to decide what i was going to use for the inside. I wanted three levels to make it simple to do and roll the dice enough to work correctly so i went with three layers. I didn't want to use more then the one sheet of foam board and i wanted to put a distinct sound to them. i grabbed two sheets of sheet styrene and cut them into 3rds. I didn't measure this part at all i just kinda eyeballed it:
I then folded up the corners to make them level and angled to the way i wanted them to be. I then used Blue tac to set them where i wanted them and glued them in:
Glued on the rest:
Oh look! Test subjects!
TADA!!!
Someone probably made this in another thread, Hats off to you sir, just spreading the knowledge.
If someone tells you "They look like an orc built them." Tell them "that was the idea the whole time".
More in a few
Moe
