oistene's WIP - a mostly dead space
Digganob
Them crazy horses and their backwards tails. I tell you, you just can't get anything serious out of those guys.
Maenas
I think Bam's painting spirit has imbued Oistene and now he is slowly turning into a painting OsiteneBamachine... *badumtish* lol
I also liked those horses skin colour.... I can feel that colour sense changing on you too ;)
oistene
Machine-like painting is pretty much due to life kicking me in the face a lot these days. Painting is pretty much the only thing that soothes me and that I can easily carve out time for. I guess it could have been worse, I get painting done.
Finished up the bane knights yesterday (those last steps always take longer than I think), here's some lousy pictures:
View attachment 43950View attachment 43951
After this, my desk turned into a chicken coop:
Had a go at using the airbrush to shade these guys. I still have a long way to go, but man oh man that things is a time saver! These were primed and base coated before I started yesterday, and now they are close to done. They are pretty large models, so the airbrush has saved me hours and hours.
ArchArad
I'm sorry that life has been a b%@$#. *hugs and offers oistene a helmet*
The bane knights look great - a nice uniform look across the unit, but each model is still unique. I particularly like the work you've done on their robes with the blues and greys.
oistene
Okay, this is what I am doing now:
View attachment 44262View attachment 44263
This is a multi-part kit, I've magnetized it so it can be turned into three different helljacks. There's so many details and little parts - even with my relatively simple color scheme, it has been taking forever. Nearly done with the metal now, so that I can start to shade it. Fortunately, I've preshaded the grey parts with the airbrush, so they'll only need some edge highlights to pop. Hoping to get this done today.
BloodASmedium
[img]http://pnp
Awesome....do I see a misfits mug ,I know that "fiend" anywhere see em Halloween manytimes...dig up her bones mate ,hybrid moments mate.:)
oistene
Danke BAM; "Everyone" takes notice of the mug! It belonged to the wife, but the handle broke off. I fixed it once, but it only lasted a while, so now it is my permanent water cup. :)
Maenas
If you upload it to your gallery don't forget to put a pic with the different options... magnetizing is time consuming but I think it's worth the effort because you can have different miniatures in just one. I haven't tried it, but I will when I (someday) start my Skaven screaming bell/plague furnace project.
oistene
Thanks guys! Actually, Maneas, I don't think magnetizing was all that time consuming, not as prep goes. There were a few tricks to it, but once I had nailed it, it was a breeze and I'll be doing it again.
As for gallery pics - I know I should, but I suck at photography and I don't feel like spending my precious hobby time on practicing, or even taking pictures in the first place, for that matter... at the same time, I want to display my work as good as possible, so it is a bit of a Catch 22. "Maybe later" is the mantra I live by.
fluister, with this kit finished, my regular 35 pt army is actually fully painted, which is a first for me! Still need a few more minis to get the 50 pt done, with options, but I plan to get there.
oistene
Lots of painting, little CMoN posting these days, this is mostly because I do quick jobs.
I'm trying to use my airbrush as much as possible, to get the minis faster on the table. It's a learning process, to say the least. While some things come easy, other things I really struggle with. Getting the work flow right and figuring out of to mask effectively (or when to not mask at all and rather fix it by hand) is on the top of my list.
I've done some work on my Bile Thralls the last few days. It can pretty much be summed up as 'hrmph'.
Metal done by airbrush, liquid mask placed, added some purple to the base for shading. No problem!
Base flesh done. Tried to add some darker green, but it hardly showed on the purple and black, so I skipped it. Tried to keep it from above as much as possible. Few problems.
Like so. No problem! I'll add some more dark green and purple by hand later.
Mixed first some bone, then some ivory in the necrotic flesh, for highlight. No problem!
And this is where I am at now. It was all good - until I tried to get the mask of. It causes all kinds of trouble, not coming off, taking all of the paint off and so on. I found that the best way to remove it was by using a ball of dried up liquid mask, but not even that was fool proof. Never again! Next time, I'll airbrush the flesh and do the metal by hand.
I'll cover my steps below, any insight in this will be highly appreciated! I think I need to reconsider my work flow.
Maenas
Oh man that's a little nightmare!! what did you use as a masking liquid? vallejo's blue one? and what did you use to paint the base paint beneath the masking?
I read here on the forums that putting a thin layer of varnish helps in protecting previous work from that issue... I myself haven't tried it, because of this problem you are comenting... I am just a bit terrified since this seems a more common problem than it should be with a thing that's designed to do this work.....
oistene
Vallejo, yes. It's not QUITE as bad as it seems - there's still more mask on that model I need to remove, but I need other tools and I am not at home and also, I got REALLY fed up with it. Under the mask there's Badger primer, and regular acrylics (some Vallejo air and some Warcolor, if I remember correctly). I think I might have over-primed the parts that came loose. I lay on the primer pretty hard to make a good base for the metal, and that might not have been a good idea.
Next time, I'll try to get hold of Silly Putty, I hear that is good.
oistene
Okay, took me two days of cleaning while playing Fallout with the wife, but I finally got rid off 98% of the masking on the Bile Thralls. The best way I found was to use a little fresh liquid mask on a tooth pick, and then gently rub that on the old masking. Continue doing so until it starts to tug at the mask, then it can be carefully pulled off. Did less damage to the paint, but still some was left in the details.
In the end, I more or less prevailed. I re-primered the damaged parts by hand. There's way too much paint on these now (I see I've gone too heavy with the airbrush as well), but I'll cover it up with weathering and special effects - these aren't the coolest sculpts around, and I can't stand starting over. Started to repair and fill in some colors now:
While struggling with this disaster, I managed to quickly paint up two Necrosurgeons and their teams of Stitch Thralls, based them with the airbrush (no masking this time) and then did some quick brushwork. Rather pleased with the results, considering the time spent. Just a little more base work here, and they are done - meaning I am four points done on my one point per day in 2016 challenge!
View attachment 44842View attachment 44843
My phone camera is getting more and more dirt in the lens, I see... good to know it is almost time for a new phone.
Terrafirma
Looks so good Oist , well done .
keep painting dude , I've found that my bright painting light keeps the black dog off my back many times .
SaintToad
I really like the gross purple skin on that necrosurgeon. I think a little quick texture on the skirt (giving some highlights at the same time) would make it more of an eye-catcher. Nice job in any case.
oistene
Thanks Terra, a little painting is indeed what makes a good day for me. Life is full of stress, frustrations and disappointment, but the brush wipes all of that away. At the painting table, there is no stress, frustration is learning and disappointment seldom comes as I aim high but expect low.
Glad you like it, Toad. I considered pushing the highlights on the skirt, but kept them low on purpose, part to save time, part because the mini is very busy as it is and part because there weren't much folds and the like sculpted into it. Texture might be nice, though... I've glossed it now, but I'll consider adding a little pigment for texture before sealing with matte. Would only take me five minutes.
Turns out the Bile Thralls are salvageable. They won't ever be my best work, but will fit into my table top standard. I've basecoated and shaded everything but the skin now, after adding highlights and some magic tricks to the skin they should look alright.
Some green and purple shading will sicken the skin, I then consider adding some dark greenish black veins to the skin to pull it up a notch.
