Ork Conversions
CreganTur
This is my first experience doing detailed conversions on any minis, so I would greatly appreciate any C&C or pointers you guys can provide.
So far I\'ve only completed one of the Orks that I\'m converting. I started with this guy here:
I don\'t need the axe for what I have planned, so I snipped it away and cleaned up all the mold lines. Then I scratchbuilt an orkish beer stien for our friend. The handle is bent styrene round rod, the stein is styrene round tube, and I used GS for all the other details. You can kind of make out a little design on the band around the center of the mug- I used the end of a mechanical pencil to place little marks around the band. I\'ll paint it to look like a decorative brass plate was riveted onto the sein. Gotta love Orkish engineering!
The left arm was holding a pistol of some sort, which I don\'t need at all, since this hand is going to have the Pointing Finger Of Doom! This isn\'t a cliche, as he\'ll actually be pointing at something when I finish this project.
Getting everything off without ruining the hand was a hard job, but I finally managed. I used twisted 28 gauge steel wire for the finger:
Aftr picking out a head, I attached the arm and GSed the gap. Then I sculpted on a new finger, which includes a fingrnail clearly marked, along with the line of the glove marked as well, but that\'s hard to see in the pics. I also made some lines with the end of a needle to indicate wrinkles in the skin around the knuckles.
I also sculpted some foam onto the top of the beer stein. I started with a small ball of GS, which I slowly formed so it covered the top of the stein, and then I pushed it down the side where it\'s leaning forward, to show a little spillage. Then I used the end of a pin to poke a lot of little holes into the entire foam section. This is a beautiful effect in person, and will look great when it\'s all painted up!
Whatcha think?
CreganTur
Here are the last 3 Orks for my project. Sculpting the hand on the guy in the middle was the biggest challenge, but I think it turned out really, really well. I actually cut the leg off of the guy on the left and repositioned it
This is my favorite part of the project: the base. My father-in-law carves bowls and decorative boxes on a lathe, and I worked with him to create this base. He let me turn a prototype with a soft, white wood, and then he recreated it in mahogany. The base only has 2 coats of clear varnish- all of that color is natural wood!
The top of the base is ~ 4 1/8th\". Plenty of room to setup my diorama. The little ring you see on the top of the base was carved there- I\'m using it to mark the boundry of the diorama.
All I have left now are some props, which I\'m probably not going to show, because it would give away the whole concept ;)
Once they\'re done, I\'ll start painting.
NinjaEdit
: Wow... that first pic is really, really dark! Sorry guys, it wasn\'t that dark on my home PC.
CreganTur
Since I don\'t have to keep this project a \'secret\' anymore, I wanted to post the Ork I just finished for my Wargames diorama.
Please give me some good, honest C&C on this mini. The pics are as close to what the mini looks like as I could make them- had to play around with Photoshop\'s Level\'s commands to get them looking this good. If you get really, really close to your monitor and squint, you can barely make out the red eyes that I gave this Ork. I wish you could see them, they look great in person.
I really need some help with the fur on the helmet. For some reason, fur is very hard for me to paint. I wanted to do a brown shading into grey, but am having a lot of trouble with it.
The black pants were highlights with dark blue tones, and the black leather boots and gloves were highlighted with grey shades. I also used Black Ink on the parts of the leather that I wanted to have the deepest shadows.
S
Shadzar
So the underfur is brown, but the top fur is grey?
I would just drybrush the grey onto the high parts.....
What is he drinking? Some kind or grog or some axle grease?
CreganTur
It\'s grog. I didn\'t really have a specific drink in mind, I just wanted to show a very thick headed beer, becuase it\'s a good looking effect.
CreganTur
CreganTur
I\'ve finished 3 of the 4 Orks for this diorama. I used some WAMP suggestions to finish the fur lined helmet for Mr. Pointy.
Any feedback or suggestions?
