Imroved hold
If the magnets aren\'t holding as well as you would like, go to your local harware store and pick up some 16 ga steel sheet. Bring one of your magnets along just to make sure it\'s magetic steel. If it is, take it home and cut a little piece out and put it between the two mangets you are using. This should increase the field by about an order of magnitude or two.
