Origineel geplaatst door green stuffShe\'s as skinny as a fianna but doesn\'t have their \"implants\".
Ok, I just measured a fianna to check:
- the body is pretty much perfect 8 heads high. This is a traditional idealised ratio which gives an elegant type of figure (7-7.5 is a more realistic ratio). Going from the diagram that goes with it:
-shoulderwidth is correct in the ratio, about 2 headheights.
-breast height is right.
-het croth is about 1.5mm too high giving her elongated legs. This is a trick used by fashion designers to make their model sketches look elegant.
-arms are have also been lengthened with about 1.5mm.
- unnaturally skinny and thin in the legs.
So for the face it could be a good reference.
I\'ll send you a 36mm diagram, so you can check your mini.
As to how we go on. How about seting a date for all sketches of the angel to be in so we can decide on a final design and start dividing the work? EDIT- ok, saw you just mailed that.
