Slime or Saliva.......
mrephunk
I want to have an alien miniature that has slime coming out of his mouth much like this:
but not sure how to go about doing it. What do I use and how should I go about using it?
Wren
Woodland Scenics Water Effects is a thick gel that dries transparent and can be roughly shapped. If it needs to be freestanding, you might need to use a core of fishing wire or cut clear plastic as thin as possible from a piece of blister. It would also work for something dripping down the chin that's supported. Just get a small glob on the end of a toothpick and 'draw' lines where you want them. Once it sets (very small streams like that will set quickly), you can go back in to add bumps and droplets and thicken it up in places. I've also used 5 min epoxy at around minute 4 to make icicles. Saliva might be possible, but I think the Water Effects would be a much less irritating way to do it.
If you scroll down to see the figure next to a fountain on this page, I did the water streams with Water Effects over fishing wire. http://www.darkswordminiatures.com/gallery/GRRMline_Cersei.htm
In this pic, I did the wax drippings on the candle as I described above. http://www.coolminiornot.com/173708
mickc22
Granddad!
I used Vallejo water effects and the clear thread used for making necklaces, cut a suitable length, and apply the effects till you are happy, when it's dry you can also color it if you wish
that's what I did with my Skaven bust
http://coolminiornot.com/217855
try some light fishing line (4 lb test) and some tacky glue
The fishing line will help the tacky glue stay where you want it.
mickc22
Granddad!
UHU is just a clear general purpose glue, but not a PVA, for bonding paper, card, rubber(I think) those kind of things
Do you have some thing like that there?
