Congratulation! Nice piece. I'm fan of your style.
I don't want to spam this log with my personal messages, I will update my log soon. In short, it was Warhammer Single Miniature and Dragon Slayer.What category did you take home silver with Persifal? And what mini did you use?
Searched your blog for how you made this epic rock and couldn't find anything. When you have a moment, can you quickly describe what the rock is made from, and how you painted it? Really been leaning on you for inspiration lately![]()
Sprock, silly me I have another question for you. Please feel free to answer AFTER basking in your victories at GD. Don't want to take up your time with my annoying questions when it's so close to G Day.
My my question is a general one concerning your process. I see that on your blog you always mention a basecoat, a shade, a midtone, and a highlight. I am assuming you paint in this order for most projects. I am also deducing that your basecoat is normally between your midtone and your shade. But why is that? Why would it be this way and not just basecoat with your midtone? Because of lighting, for instance, if an object were to receive mostly midtone and highlights with a small shaded area, would you then basecoat with a lighter color? Thanks, just exploring your way if doing things. When I painted my first display mini, now that I think of it, I always base coated with a darker than midtone color. Thanks brother for your help and break a mini's leg.
Well done on the bronze! Outstanding for two weeks. If you don't mind me asking, how do apply your paint to un primed plastic? The one time I tried, I found it didn't want to adhere to where I was trying to put it...
The 'rock' is a piece of wood I picked up from the roadside. It was just one of those lucky finds that come along every now and again. The painting of the rock was relatively simple as it has great textures. The bulk of the work consists of dry brushing increasingly lighter shades of grey over a brown base colour. There is then a little work with some glazes, layering and washes just to tidy things up.
My method tends to vary depending upon the mini and the specific colour I'm painting. For example on flesh for the Frog & the Haomonculus I started off with a light base colour. I then worked down in gradual stages of layering & glazes to the shadows. The last stage was to apply the lightest highlights. On the inner (purple) skirt for the Haomonculus I started off with a dark base colour and worked up through the mid tones and then finally the highlights. Other times I may well use a mid tone base colour and then add shade & highlights. It all depends upon what effect I'm going for and what seems to be the best way of painting a particular mini or area of a mini. The one consistent thing is that I always add the final highlights last as this pulls it all together.
First up I make sure the surface is totally free from any grease or dust by giving it a thorough clean with an old toothbrush & and a dot of washing up liguid. I then paint on the base colour in several thin layers. It dosen't always go down very evenly at first but each coat covers a little more than the last. The trick is to work with very thin layers of slightly diluted paint and to make sure they are totally dry before the next one is applied. It can be a time consuming process but it builds up to a smooth even finish.
