Yeah, I thinking I'm going to be resigned to just having a bit of excessive flash on Flash. Poor guy...
Tonight had three pours, one of which is still in the mold, so no picture yet. And I got the order reversed on them below. The one on the right was with my original resin, which is supposed to be just 1 minute or so of working time before it sets. The hope was that the shorter setting time would reduce the amount of flash getting in by setting up faster. But, even though it was thicker and quicker, it still had the flash. And on top of that, a bubble in the toe. Which was the major reason to go with the slower resin in the first place.
So, faster set time doesn't work. If you notice in the previous pictures, a lot of the flash is around the middle of the mold. Experiment time. I got rid of the two wood pieces that were meant to not concentrate the load in any spot. That may be the problem. It's a pretty thin casting compared to the thickness of the mold, so might be able to withstand a direct clamping action. On goes the spring clamp right over his midsection, and that's the result on the left.
As you can see, the flash was reduced, quite a bit actually. There's still a lot near his legs, so that's the third pour of tonight. I put the big spring clamp on the lower half of the body, then put a smaller clamp over the upper section. I'll post up a picture of what that did tomorrow if I'm not too tired. Got the wife's craft show tomorrow, and last year was so busy she needed help nearly the entire day. Works better with two people anyway, for breaks and whatnot. But, 10 hours in a little 8'x8' area doesn't get any minis painted. Or cast. Or is conducive to a relaxed state. So we'll see.
