Using modeling sand for the base
J2FcM
I dont have experience with modeling sand, but I am wondering it wil \"cheapen\" the look of the base... So far I have a cracked desert path leading from my mini on the base, but I was going to surround the path and mini with sand. Any idea\'s on how well sand mixes with other terrain types? What else is good for desert type wasteland terrain?
Sand Rat
I know not this modeling sand you refer to but I use genuine Sandstorm Sand (TM) from an Iraqi sandstorm on my bases and dont seem to be having any issues with them looking cheap.
Hinton
I\'m not sure what modeling sand is. I use some stuff that my local craft shop carries called Scenic Sand. It\'s regular sand in various colors. After I glue into place, I paint it to get the look I\'m wanting.
J2FcM
Well, this is what I got so far... I am really... skeptical about how it will turn out. But I was thinking of putting scenery sand around the GS dried cracked wasteland stuff (which is like eminating from the wizard). I was just debating wether the sand texture would look goofy with the cut up GS. Any other ways to transition from cracked wastland into regular sand\\dirt?
Any suggestions on the GS work? or colors? (i was thinking brwn dirt, and the cracked stuff like black (charred!))
of=50,590,442
of=50,590,442
Hinton
Not sure how it would look; never tried it myself.
If you want to get an idea, though, here\'s a site with a few pictures of dry/cracked earth:
Mud Textures
Hopefully there\'s something there that can help you.
mczolton
Do you mean the GamesWorkshop modeling sand? If so, I just started using it myself. First time around, I noticed it sucked up a LOT of paint. I would suggest a thin coat of PVA glue before priming and painting it. Otherwise, I like it.
Mark
Shawn R. L.
One thing I dont like about alot of the sand and such you can buy is that in one bag it\'s all exactly the same grit. It ends up looking like a zen garden. Too perfect and uniform. I just use dirt form the yard because there is fine dust, fine sand, regular sand and small pebbles....just like real life.
J2FcM
thanks for the link Hinton, there are some helpful texture examples there.
I think when I get time and the outside dirt dries Ill snag some and do a dry run with modeling sand on one half my base, and outside dirt on the other side... I looked at a base made with the modeling sand on it, and I felt like it looked like gravel.. instead of sand\\dirt. The grains just seemed a bit bit to be dirt... but again, I\'ll get a picture up soon.
Hopefully it\'ll come out nice seeing how cutting up GS into pieces was a beeotch
Ogrebane
I refuse to pay good money for something I can get out of my own garden. If you want to buy sand get it from the hardware store for a couple of dollars for a wheel barrow full. I agree with shawn tho I hate the same grain sand and make my own mix with different sixe grains in it. It looks more \"Realistic\" and yes sand or dirt will soak up alot of paint thats why I always under coat it with PVA and black paint mix.
Good luck.
J2FcM
How do you... PVA undercoat??? Water + PVA glue, \"painted\" on top of the sand\\dirt? How muc water?
J2FcM
COMPARISON
Ok... first... modeling sand:
of=50,590,442
second... dirt from outside that was sifted thru a strainer:
of=50,590,442
The outside dirt is much finer... The modeling sand seems to fit better with my cracked up GS though... any thoughts? I sort of like how near the edges it thins out and some pieces are scattered into the cracks. But is there something I don\'t see to it? ALSO... Im not sure how I would color the finer outside dirt... How can highlight and shade that which is so small??????
of=50,590,442
Finally, I pondered lining the area around the cracked terrain with the more coarse model stuff, then shift into the finer sand.
Dammekkos2
The best sand for basing comes from the pet shop though, the type they use for bird cages etc. I bought some a few years ago for 50p, the bag of sand was about 20 or 30 times bigger than the GW \"Modelling\" sand (£3-4?).
blend them. get a nice range of sizes that way. Without sand, that will look like a dry lake bed with the clay all cracked and open.
Much of the GW sand is not silica if it is soaking up paint. Sounds like a lot of model railroad ballist which is clay.
You will want to give it a dark well thinned wash and a final drybrush highlight to give the sand some extra depth otherwise it will look like a toy soldier on a sand base.
demonherald
maybe worth adding a little textre to the areas first by blending some lumps of GS around to provide a more uneven surface.
J2FcM
priming and glue.
is PVA better than white glue? I\'ve been using white glue on CD cases, and found it... well isn\'t that good. Should I use wood instead of CD cases and PVA glue?
Also, is it more sensible to prime your base... and gravel in this instance? I would assume so as it will match the painting better... but maybe there is incite Im missing...
F
faulkns
White glue is also PVA glue and is also not - confused?
PVA is the one to use. It is white. Make sure you don\'t use wood glue. PVA washes out in water as well. Dilute it down a bit before you dip in the sand and make sure it dries totally first
Totally agree with your second comments though. I always glue on sand & gravel Before I prime. Gives another layer of binding, makes it easier to paint as it doesn\'t soak it up as much.
Did these like this
Now I\'ve graduated onto making my own mixes with sand and gravel to get the look I want. Try it
