Put it in the Airing cupboard for a couple of days, the warmth should help with the Varnish 'baking'.Cheers crispy will leave it alone for now although its been a while alreadymight have to strip it and start over.
seems to be toughening up I think my mistake was applying too much at a time, I completely ignored the "thin layers and many of them rule" ignore this at your peril. The varnish is "Daler and Rowney" gloss varnish for use with acrylics.
Of course it depends on whose Varnish you used, both GW & Army Painter normally dry within 24 hours................BUT with the unusually hot weather in the UK ATM it may be that the varnish isn't being mixed properly with the propellant. (Just had a Primer misbehave on me because of the heat, kinda my fault should thought and have given it more rattle)
Cool.Glad to have been of some help at last.Dr your suggestion was spot on the arm has been in the hotpress now since you posted, its rock hard yeah!
