Demihuman's DemiWIP
Demihuman
PHOTOS!
looks good and I would be happy to paint armies to Angel's quality. I thought it was a good look at an alternative method to the Figopedia book (which is drool worthy).
Yeah, definitely. I also think that there is stuff that looks really cool on an army that doesn't look that great on a single figure. Like super forced highlights or OSL sometimes.
In other news, the Pathfinder made the new and Notable box! W00t! Gonna have to put it up on putty and paint now.
http://www.coolminiornot.com/385360
I also put up some of my D&D stuff:
http://www.coolminiornot.com/385668
and
http://www.coolminiornot.com/385669
ArchArad
Hey Demihuman. I saw your D&D figures yesterday and they look like a lot of fun. Two of my favourite things in one place - mini painting and roleplaying/story-telling.
Demihuman
Thanks ArchArad, yeah I am an RPG guy too. They were super fun to paint. There are a lot more pictures of them in my WIP if you go back a few pages.
oistene
Yeah, just like Digga, I wish I had more RPG time. RPG and LARP used to be my preferred hobbies, but board/wargames and mini painting is just so much easier to fit in with family time.
While we are on the topic of Angel's book - I'd like to learn about airbrushing, is this a good choice to pick up for that? I've heard a lot of folks rave about it, but little about what's in it.
Maenas
Voted! ^^
.../I'd like to learn about airbrushing, is this a good choice to pick up for that? I've heard a lot of folks rave about it, but little about what's in it.
Nope Oistene, I don't think so. You'll get 6 text lines about which setup he uses with his infinity airbrush. And lots of SBS <-- I think you can get them (not the same and maybe not that detailed) also on his facebook page. And some tips about masking. thats it all for the AB issue. Obviously you can read lots of info in the SBS pictures but I'm sure there are better airbrush focused books than this one is, although I do not know of anyone of them. I think that the book is only profitable to people that already know how to use an airbrush and know how to read the info on the images because text almost all the time only goes like "put a 50% mix of colour A with colour B into that part, highlight with a mix of B plus C etc.." with a tip or two sprinkled among it.
Is not that I am happy with the book is just I find it super sci-fi focused and for a level of AB that I still haven't reached (just basecoated some minis with it) just my opinion of course.
ten ball
I just messed around with 'my' (Andys) AB, you will learn quick and its more fun than trying to follow an expert. :)
Used this old marine as a test piece. Just a base coat of blue, then practiced with shading / highlights by adding greys.
A good tip is just to spray water onto paper at first to get use to the spray / pressures etc. + you dont need to wear a mask with just water.
Demihuman
Yeah, the book really is "Master Class" There is a bunch of stuff that he sort of expects you to already know. I am very happy with it now that I am digging into it.
I think the greatest thing to learning how to use an air brush is if you can get someone to give you even a really short demo. One thing that is hard to get used to is how fast it will produce a nice blend. It is really easy to spray and think, "oh that looks nice" and in the time it took to think 'it looks nice' you have increased the size of your highlight to cover the whole mini.
The other thing that is really tricky at first with the airbrush, is there are several different problems you can have that all give the same symptom. If your pressure is too high you will get pooling or spider legs, if your paint is too thin, same thing. Not thin enough paint, you can get stippling or it could be low pressure, or you could be holding the brush too far away.
Another thing that is tough is that your air brush will clog a TON when you are starting out. I hardly ever get clogs now and I am not really sure why. One easy trick to get rid of a clog is #1 anticipate the clog. If it seems like not enough paint is coming out and you aren't running out of pressure or paint then you are probably developing a clog. Point your AB away from your project and give it a full paint full pressure blast. That will usually push through the paint that is trying to dry up on you.
Another way your airbrush will clog is tip dry, especially with white. An easy way to deal with this is to clean the tip of your airbrush. Use one of your good old paint brushes, something that is still really soft and decent, dip it in rubbing alcohol and GENTLY wipe any dried paint off the part of the needle that is exposed at the front of your airbrush. Then give a poof to get rid of any residual alcohol and you are back in business.
A great exercise for your AB is zenithal priming. Prime black and give the mini a splash of white from the top with your airbrush. You will see how the paint falls, then try and do a small spot with the white, like a hand or the tip of a sword.
The next exercise would be to take that a bit further and prime black, give it a splash of white then a light base coat of your primary base color then, as if you were doing a zenithal prime, give it another splash from above but with a highlight color, good fun! If you like the results seal them!
Then the final micro exercise would be to do he zenithal prime but instead of going from black to white try to build up to white with shades of grey then all the way up to white. Then try doing the same with your base coats.
The Studio Giraldez book starts with airbrush individual highlights over a base coated mini.
Here are some AB tips:
-You have to thin your paints! Just use WATER and your regular mini paint at first. Figure out how that works, then you can start using all kinds of additives and highflow inks and stuff. I like to thin just like I would if I were basecoating a mini and wanted a nice even layer with 2 coats of paint.
-The airbrushed layer is really thin and delicate, so it's easy to damage, but also real easy to strip. Keep a pot of rubbing alcohol nearby while you work, it's good for cleaning your brush too (booze works good too)
- Before you start with the paint, learn how to take your airbrush all the way apart and put it all the way back together. Go slow, don't bend the tip or force anything. don't do it over carpet or on the couch, you will lose a tiny screw or something. make sure you have the right tools!
- When you change colors you should swish out your left over paint, then run enough water through the AB that it runs clear, then spray a couple of drops of pure alcohol, then water again and you will be ready for the next color. If the water doesn't come out in a nice continuous, well shaped spray, you have a clog, pull out the needle and give it a wipe and good visual inspection. Try again, still clogged? You need to pull apart your AB and give it a good cleaning.
-You need to get really really close to make small lines and dots. It's a cone shaped area of effect here :)
-practice practice practice!
If you have questions hit me up! Maybe we could set-up a Google Hangout or something.
ArchArad
I'm still trying to wrap my brain around brush techniques! So I think I'll leave the airbrushing to the more experienced.
oistene
Thanks for the write-up, Demi! I really need to find myself some airbrush-friendly projects so that I can give this a go. I did try some quick basecoats on some zombicide minis, but other things got in the way before I bothered to try anything more fancy. As for getting someone else to show me - there's not a lot of very good painters around these parts (or if there are, I don't know of them) so getting pointers is hard. I'm infiltrating the wargamers though, I might be able to find someone with some mad skillz.
Demihuman
Thanks guys! The airbrush stuff has been kicking around my head for a bit. It's a great tool once you can get consistent results with it. I finished the infinity robots. I think they are going to go on e-bay too. I still haven't got a buyer on the pathfinder but I have gotten like 2500 views so I must be on the right track...
I'll put up a gallery link asap :)
Digganob
Those bots came out pretty dam good. Did you use the AB for the entire thing? I think there are parts to small and need a brush but you blow my mind with the stuff you can do.
Darthmarsh
Great tips on how to use an AB Demi. I need to break mine out more, I've only used it once! Bots look really cool they have a great manga vibe
