Here are the colours I’ve used for the NMM on CHee-Chee.
All of my NMM is highlighted with ivory. Keep white to an absolute minimum and use it only for the smallest & most extreme highlights to give your NMM a glint.
Copper
Base colour: Mournfang Brown/Ratskin Flesh mix
Shade: Rhinox Hide
Mid tone: Ratskin Flesh
Highlight: Valejo Ivory
The key colour for the copper is Ratskin Flesh. I like my copper to have a pinkish tinge to it and Ratskin Flesh gives me exactly what I’m looking for.
Gold/Brass
Base colour: Mournfang Brown/Iyanden Darksun mix
Shade: Rhinox Hide
Mid tone: Iyanden Darksun
For the mid tones pick a muted yellow ochre and avoid too bright a golden yellow colour. I get a more pleasing (to me) result in all my NMM if I keep to a muted palette and steer clear of bright colours in the mix.
Bronze
Shade: Rhinox Hide
This uses the same colours as the gold but mixed to create a muted & darker effect. The mid tones use a lot more Mournfang Brown in proportion to the Iyanden Darksun. I wanted my bronze to have a dark patina so I restrict the brighter areas to where the metal would be polished by wear & tear.
Iron/dark steel
I’ve used a conventional mix of cool greys but the addition of a little Thunderhawk Blue really gives the colour a lift.
Verdigris
The idea is to create a stained look with tidemarks left behind as the paint dries. The exact opposite of what you would normally do when applying a wash!
I’ve used a dilute mix of Ivory and Hawk Turquoise applied as a wash and allowed to pool where you want the verdigris. As the wash begins to dry dab in a little more of the un-mixed but diluted ivory & turquoise. The colours will run into each other and partly blend as they dry. Once dry repeat until you like the look of it.
